SW2018 SP2.0
I'm having a heck of a time with trying to create crop views. I sketch a profile (circle or rectangle), making sure that the correct view is active and attached to the sketch.
Then I hit Crop View...and it asks me to sketch a profile.
It doesn't seem to recognize the existing profile. If I click over to the sketch tab and make another profile, it just creates another profile and forgets that I was trying to crop.
If I do this three or four times, it does work and I can crop the view, then I have to delete the sketches that didn't crop.
I'm not sure if I'm doing it incorrectly or if it's a bug.
*Edit*
Thanks everyone, I seem to have it figured out. It does seem to work most of the time, if I create the sketch then immediately go to crop view (don't click anywhere which deselects the sketch). Getting it to work if there was a break in the workflow, requires that you select both the view and the sketch before hitting crop view.
Also, is it weird that when I crop a view, I don't have the option to undo it? I have to find the view, RMB, crop-->remove crop.
Message was edited by: Mike Hodson
My testing in SW2018 sp2 yielded:
If you create a center rectangle and start the crop view right away, it works even with the construction lines and point selected.
If you create a center rectangle and don't start the crop view right away and reselect all of the entities, crop view complains and fails.
Below, I interrupted the workflow and I've reselected everything and clicked crop view:
When I reselect by Ctrl+clicking just the solid lines, crop view works as intended w/o having to recreate the sketch:
So:
I hope this helps.
Cheers,
Kevin
