pass parameters from configuration to drawing file
Question asked by Rodney Martin on Apr 18, 2018
Latest reply on Apr 18, 2018 by Jeremiah Feist
Not sure where to ask this one.  I badly need properties in model/assembly configurations to pass into drawing files.  I thought just adding the properties to PDM was enough to keep everything sync'd.  How do I get properties linked between part/drawing?
Also, I need a good way "after the fact" to populate drawing files with the part properties.  First priority is to get everything working properly from now forward.
Here are my settings.
PDM:
Part Properties:
Drawing Properties:
What you see actually works.  If you update Revision in the part, the drawing parameter updates.  I need to push all of the other parameters in the same way.  However, if I add the property name in the drawing table, it is independent.  How do I link the two together?
