Help with Macro for Adding part of File name to Property
Question asked by Daniel Finn on Apr 18, 2018
Latest reply on Apr 19, 2018 by Christian Chu
I would appreciate anyone that can help with this.
To briefly explain what i am trying to do, we name our files as following eg: TE1234 Description
I want to pull out the first 6 letters which i have succeeded in doing using the following code:
Dim swModel As ModelDoc2
    Set swModel = swApp.ActiveDoc
     swModel.DeleteCustomInfo ("JobNo")
    swModel.AddCustomInfo2 "JobNo", swCustomInfoText, Left(swModel.GetTitle, 6)
The issue i have is that there are occasions when a part may be labelled what it is eg: M6x12mm Screw
With this macro it pulls through the first 6 digits.
Is there a way to specify for instance, if the filename does not start with 2 letters and followed by 4 digits then ignore and leave blank
Any help would be appreciated with this
