My assembly drawing file has 16 sheets. Is there a way to link the SHEET NUMBER column of BOM TABLE to where the balloon belongs on a certain sheet? Or can I only do it manually to fill in this column?
You might be able to get away with using flag notes and their zone location (which also references sheet number). I am not sure if it will work, but you could give it a try.
https://www.javelin-tech.com/blog/2016/12/solidworks-flag-note/
https://www.javelin-tech.com/blog/2016/07/solidworks-flag-notes-link/
I don't know how to link it to a BOM and I am not sure if a balloon from a flag note will convert to a balloon from a BOM.
But, you might be able to get away with a Numbered set of notes that links a flag note to each balloon. Would be some work, but would update for you (I think).
You can always make a sheet number customproperty which can be linked to the bom but as far as filling it in automatically, I don't think there is a built in option for that. Maybe someone can chime in with a macro if it is possible.
