Having issues following the documentation finding specific methods, etc.
Question asked by Gary Johnson on Apr 17, 2018
Latest reply on Apr 17, 2018 by Artem Taturevych
In the code below I am trying to "get" a pdf so that I can open it and print it from a .Net DLL.  My current specific question is in the line .AddVariable("X",retVal(0)), where retVal(0) is the name of a file, what is the first parameter (that I have set to "X")?
More generally, how can I find documentation to this level?  I have spent most of this afternoon trying to go through the EPDM API help.  While I can find, for example, IEdmSearch7, I cannot find anything that documents the properties and methods of that class.  Because this one implements IEdmSearch6, and that implements IEdmSearch5, I also looked at the documentation for those.  Again, no luck.
So -- obviously hoping you can help with the first question so that I can move along with my project, but also hoping to figure out the documentation so that I don't have to keep asking questions and bugging people!
Thanks.
                        Dim search As IEdmSearch7 = vault.CreateSearch
                        Dim item As EPDMItemA = Nothing
                        'search = vault.CreateUtility(EdmUtility.EdmUtil_Search)
                        With search
                            .FindFiles = True
                            .FindFolders = False
                            .Recursive = True
                            .SetToken(EdmSearchToken.Edmstok_FindItems, True)
                            .StartFolderID = vault.ItemRootFolderID
                            .AddVariable("X", retVal(0))
                        End With
                        Dim result As IEdmSearchResult5 = search.GetFirstResult
                        If Not result Is Nothing Then
                            If result.IsKindOf(EdmObjectType.EdmObject_Item) Then
                                Dim file As IEdmFile8 = result
                                Dim edmItem As IEdmItem = file
                                item = New EPDMItemA(edmItem)
