The Item Explorer is used to create and view items since
these might not be documents in the vault and therefore do not show
up in the Windows Explorer.
Dear All, I'm battling to Install Item Explorer. I've chosen
"Custom" option as advised. But under Client tree I can't choose
option for installation of Item Explorer. Is anybody expirienced
the same problem?
Sorry If my Quote Off-Topic
The first step is to install the client (which you've done), the
next step is to configure Items in the Admin tool. You will not see
the Item Explorer icon within the Windows Explorer vault view until
you set an Item serial number and such.
I recommend:
1. Create an Item Serial Number
2. Click on the Items node in the add-in tool and configure.
The first step is to install the client (which you've done), the next step is to configure Items in the Admin tool. You will not see the Item Explorer icon within the Windows Explorer vault view until you set an Item serial number and such.
I recommend:
This will give you the Item Explorer node.
Refer to the on-line help for more information.
Best Regards,
Joy
