Hi
I am creating a drawing of my part and i have all my settings to follow ISO-formatting. But when I try to Project a TOP view below my primary FRONT view it shows me the BOTTOM view as in ANSI-standard. How do I change this?
I use SW 2017
Hi
I use SW 2017
The problem I had is now solved. I just wanted to comment on this: Since first angle projection is part of the ISO standard of visualizing your part shouldn't it be set to first angle when you choose ISO as the default drafting standard in the Document Properties?
I have to agree with you. I've never understood why that's in the sheet properties, and linked to the sheet format, instead of at Tools > Options > Document Properties where it could be linked to the drawing template.
