BVBen Van Der Linde16/04/2018
Hi Soildworks Forum,
Can someone please help me with this code.  The code:
1. calls a custom property
2. looks up the custom property value in a excel table with Vlookup
3. Export custom properties (have not written this part of code yet)
Unfortunately I cannot get past the Vlookup section and I don't understand why.  Can someone please help me understand why I keep getting a run-time error '438' Object doesn't support this property or method.
Thank you in advanced for the help
Option Explicit
Dim excApp As Excel.Application
Dim excWorkbook As Excel.Workbook
Dim swCustPrpMgr As SldWorks.CustomPropertyManager
'Soildworks set
Set swModel = swApp.ActiveDoc
'stop screen updating
'Application.ScreenUpdating = False
Dim sDriverCode1 As String 'Driver code
Dim rValOut As String 'Unsure
Dim bool As Boolean 'unsure
'current value of custom propery DRIVER
    Set swCustPrpMgr = swModel.Extension.CustomPropertyManager("")
    bool = swCustPrpMgr.Get3("Driver", True, sDriverCode1, rValOut)
    Debug.Print "Driver Code:              " & sDriverCode1
    Debug.Print "Evaluated value:          " & rValOut
    Debug.Print "Up-to-date data:          " & bool
'excel set
Set excApp = GetObject(, "Excel.Application")
Dim sDriverPath As String
Dim sDriverExc As String
Dim sDriverFile As String
Dim sDriverSheet As String
Dim sDriverRange As String
sDriverPath = "P:\Path\"
sDriverFile = "Driver.xlsx"
sDriverSheet = "Sheet1"
sDriverRange = "A1:H1000"
'open Driver Excel
Set excWorkbook = excApp.Workbooks.Open(sDriverPath & sDriverFile)
'On Error GoTo MyErrorHandler
'Vlookup of file
Dim sManfact As String
sManfact = excApp.WorksheetFuction.Vlookup(sDriverCode1, excWorkbook.Sheets(sDriverSheet).Range(sDriverRange), 2, False)
Debug.Print sManfact
Exit Sub
MyErrorHandler:
    If Err.Number = 1004 Then
        MsgBox "ItemNumber Not Present in the table."
