Hello friends:
I'm trying to do something similar like the attached PH file (this came from a .stl file, not editable) for a university project. I don't have much expertise in SolidWork and don't know if I'm in the right way, but started with 2 surfaces to then use the knit surface with the option of create a solid and merge the entities, but solidworks gave me an error saying the a solid can't be created. Please check my file MO1.
Any recomendations?
Maybe I should start with a 3D Sketch or other way unknown to me?
Somebody can help me with some intructions to do what I want using surfaces.
Thank you all¡¡¡
Hi Francisco,
Create a surface parallel to the Alzado plane that is located at the corner of the small protrusion (noted in attached image) and create a surface plane using a sketch on that plane. Use that surface to trim each of the current surfaces removing the unwanted sections on either side of that surface plane that are interfering with each other. once these are trimmed you can merge the surfaces and then thicken
