Hello all,
I currently am running a macro that opens a folder browser dialogue that has a root folder as the currently open drawing's containing folder. When I use the code below, I cannot see any parent folders however. Is there a way to change this?
'Both arguements are optional. The first is the dialog caption and the second is is to specify the top-most visible folder in the hierarchy. The default is "My Computer."
Function SelectFolder(Optional Title As String, Optional TopFolder As String) As String
Dim objShell As New Shell32.Shell
Dim objFolder As Shell32.Folder
'If you use 16384 instead of 1 on the next line, files are also displayed
Set objFolder = objShell.BrowseForFolder(0, Title, 1, TopFolder)
If Not objFolder Is Nothing Then
SelectFolder = objFolder.Items.Item.Path
End Function
I come up with something like this, but I can't the containing folder (or any more after that) of TEST FILES:
