Riddle me this Batman!
Several times over the duration of modelling my truck I've experienced a situation whereby I need to create a smooth transition between a very curved surface that has boundaries with rounded corners. I always end up with a little 'pinch' (my term) in the corner. Essentially, it's a flattened area that doesn't really conform to natural roundness. In this example, I've tried adding additional horizontal projected curves, additional projected vertical curves, but still I end up with some form of the same problem.
The above image utilizes just one central projected curve
This one has the addition of a vertical projected curve.
It also doesn't help applying 'Tangency to Face' to the boundaries either.
Surely there is a simple process to achieving this that I am missing. Any constructive advice greatly appreciated.
Dave.
..ok,.. another way... (image/file attached)
