When I try to add Edge-Flange to sheet metal SW 2008 won't
add relief automatically although this option is enabled with ratio
0.5. I have to edit sketch of the flange, make it shorter so it
doesn't connect to radius of the bend to have the relief created. I
remember in was done automatically in previous versions. Is my SW
2008 not working properly? If so , how to fix it?
Thanks for help
Peter
Thanks for help
Peter
I have run into exactly the same issue, and I cannot find an answer in the help or in these fora.
Several of my corners should have auto relief and do not.
Does anyone out there have a solution for this? Is it a glitch in the software?
