SHSteve Holland12/04/2018
Hi Everyone! Here is the list of most accessed KB solutions for the first quarter of this year.To view a KB solution, click on the Solution ID.
Rank | Solution ID | Question |
1 | S-048683 | Why does the SOLIDWORKS® Resource Monitor display "system resources are running low" on Windows 7 64-bit? |
2 | S-073387 | Why does the SOLIDWORKS® 2017 SP4 software stop responding when I close files? |
3 | S-071158 | What does a SOLIDWORKS® installation fail with the error ‘register_i386_SldShellExtServerExe’? |
4 | S-069274 | Is there a tool for SOLIDWORKS® PDM that can help verify connectivity between a client and server or between replicated servers to ensure the server and service ports are accessible? |
5 | S-048684 | Why does a "system resources are running low" warning dispaly on Windows Vista® and Windows® 7 64-bit if not all of the Physical and Virtual Memory is used? |
6 | S-017133 | How can a user troubleshoot SOLIDWORKS® Enterprise PDM API add-in DLLs that fails to distribute or fails to load with error 'Failed to register the COM DLL' on client systems? |
7 | S-074167 | Why does my computer with an Intel® processor perform slower after installing a Windows® Update? |
8 | S-061562 | How do I repair or uninstall and reinstall Microsoft® .NET Framework components? |
9 | S-07981 | When installing SOLIDWORKS® Workgroup PDM server, why do I get error 1303? |
10 | S-051631 | How can a clean uninstall and reinstall of SolidWorks be performed? Is there a cleanup utility that can be used to do this? |
11 | S-073373 | In the ‘License Usage’ tab of the SOLIDWORKS® 2018 SolidNetWork License (SNL) Manager, why do I see the error ‘Could not get information from this server’ after the license is activated successfully? |
12 | S-033302 | When I run SOLIDWORKS®, I get the error: ‘Failed to initialize Visual Basic for Apps, equations and macros will not work….’ followed by the error ‘Environment variable 'temp' must be set to a temp directory’. What does this mean? |
13 | S-054855 | What can cause "Failed to initialize Visual Basic for Apps, equations and macros will not work. Are you low on disc space?" upon start-up of SOLIDWORKS®? |
14 | S-072608 | What can cause the SOLIDWORKS® 2017 software to take a long time to start as compared to the SOLIDWORKS 2016 version? |
15 | S-017826 | How can you restore a copy of a SOLIDWORKS® PDM file vault to a separate system from a SQL database backup (.bak) in order to test upgrades or troubleshoot vault specific problems? |
16 | S-020198 | What does the message "No database connected to this view" mean when browsing into a SOLIDWORKS® Enterprise PDM file vault view? |
17 | S-034751 | What could cause the error 'Archive server could not open windows registry' when creating a local view or attaching to an archive server from a SOLIDWORKS® PDM client? |
18 | S-072597 | In the SOLIDWORKS® software, when I perform various actions such as edit features, change view orientations, edit parts-in-context, or use the View Selector, why does the display or graphics area flicker or flash? |
19 | S-018842 | [...]\cosworks.dll cannot be loaded. Either the Add-in or one of its components is missing. (Version 2011 and up) |
20 | S-072437 | When I use the SOLIDWORKS® 2017 software on a workstation that has a slow network connection to the SolidNetWork License (SNL) server, what causes the error ‘Could not obtain a license for SOLIDWORKS’? |
