Is there a way to export PDFs with a black background?
The customer I'm working for uses AutoCAD for everything, so their standard is a black background. I set SWE to have a black background so that everything would look the same when it's exported as DWGs later. But in the meantime, I want to send PDFs, except they have a white background, which makes it almost impossible to see anything that's been drawn:
If anyone knows of a way to print PDFs with a black background, that would be amazing! Thanks!
Go to invertpdf.com. I'd suggest you change all the colours in your drawing to black and then print the drawing to a PDF. Then open the PDF at invertpdf.com and voila. Hope that helps, it's for visually impaired people usually.
