I am working on a small part in Solidworks with a threaded hole. The problem occurs when I try to make an extruded cut through the threads, it says "operation failed due to geometric condition". If I delete the threads I can made the cuts no problem.
Any suggestions for a solution?
Thanks.
Hi Tim,
Are you able to attach the part (inclusive of the extruded cut sketch) so that people can see exactly where the problem might be?
Dave.
