6 Replies Latest reply on Apr 11, 2018 4:52 PM by Mário Neto
    Plan with 3 points
    Mário Neto
      Hi!
      I have a macro that select 3 points, and i just want to create a plane with them, but apparently all functions that do this are now obsolete. What can i do?
        • Re: Plan with 3 points
          Peter Kennedy
          Have you looked at this:
          2017 SOLIDWORKS API Help - InsertRefPlane Method (IFeatureManager)
          Here is an example with with VBA, from what I can see you should be able to add a plane with 3 points:
          2017 SOLIDWORKS API Help - Insert Reference Plane Example (VBA)
              Mário Neto
              Hi Peter,
              I'll try it. But just to clarify: When i try to use the "ICreatePlaneThru3Point3" the plane is created, but i get an error. Why do i get an error if the plan is created?
                  Mário Neto
                  As far as i got:
                      Dim swApp               As SldWorks.SldWorks
                      Dim swModel             As SldWorks.ModelDoc2
                      Dim swFeature           As SldWorks.Feature
                      Dim swSubFeature        As SldWorks.Feature
                      Dim swPlaneFeat         As SldWorks.Feature
                      Dim swFeatMgr           As SldWorks.FeatureManager
                      Dim vSkPtArr            As Variant
                      Dim vSkSeg              As Variant
                      Dim vConfNameArr        As Variant
                      Dim vSuppStateArr       As Variant
                      Dim swSkPt              As SldWorks.SketchPoint
                      Dim swSkLine            As SldWorks.SketchLine
                      Dim value               As Boolean
                      Dim boolstatus          As Boolean
                              Set swModel = swApp.ActiveDoc
                          Set swFeature = swModel.FirstFeature
                              While Not swFeature Is Nothing
                                  Select Case swFeature.GetTypeName2
                                      Case "FlatPattern"
                                          vConfNameArr = swModel.GetConfigurationNames
                                          vSuppStateArr = swFeature.IsSuppressed2(swThisConfiguration, vConfNameArr)
                                              Debug.Print "Component Flat Pattern Supression = " & vSuppStateArr(i)
                                  If vSuppStateArr(i) = True Then value = swFeature.Select(True)
                                      value = swModel.EditUnsuppress2
                                  Set swSubFeature = swFeature.GetFirstSubFeature
                                      Debug.Print "Feature being processed is: " & swFeature.Name
                                          While Not swSubFeature Is Nothing
                                              Debug.Print "SubFeature being processed is: " & swSubFeature.Name
                                                  If swSubFeature.Name Like "*Caixa*" Then
                                                          Dim swSketch As Sketch
                                                          Set swSketch = swSubFeature.GetSpecificFeature2
                                                              vSkPtArr = swSketch.GetSketchPoints
        For i = 1 To UBound(vSkPtArr)
        Set vSkPt = vSkPtArr(i)
        vSkPt.Select (True)
        Next i
        Dim swPlane As Object
        Set swPlane = swModel.FeatureManager.InsertRefPlane(4, 0, 4, 0, 4, 0)
        boolstatus = swPlane Is Nothing
        If boolstatus = True Then Debug.Print "Plane Not Created"
        Debug.Print "Plane Created"
                                              Set swSubFeature = swSubFeature.GetNextSubFeature
                                          Wend
                                      End Select
                                  Set swFeature = swFeature.GetNextFeature()
                              Wend
                  But the the plan is not created.
                  If you are goin to test it you might want to change line 58 since i user solidworks in portuguese. It's supposed to call the sheet metal's bounding box
                      Mário Neto
                      Ok, i got it:
                      Basically, you have to select the points with the SelectByID2 function appending the marks 0, 1 and 2 respectively in your 3 points, then you can call the InsertRefPlane. My code ended up like this:
                          Dim swSk                As SldWorks.Feature
                          Dim FeatMgr             As IFeatureManager
                          Dim Value               As Boolean
                          Dim SketchName          As String
                          Dim PointName           As String
                          Dim PointType           As String
                          Dim PointSlot           As String
                          Dim PointX              As Double
                          Dim PointY              As Double
                          Dim PointZ              As Double
                          Dim Mark                As Integer
                                          Case "FlatPattern"
                                      If vSuppStateArr(i) = True Then Value = swFeature.Select(True)
                                          Value = swModel.EditUnsuppress2
        Mark = 0
        Set swSkPt = vSkPtArr(i)
        Set swSk = swSkPt.GetSketch
        SketchName = swSk.Name
        PointSlot = swSkPt.IGetID
        PointType = "EXTSKETCHPOINT"
        PointX = swSkPt.X
        PointY = swSkPt.Y
        PointZ = swSkPt.Z
        PointName = "Point" & PointSlot & "@" & SketchName
        Debug.Print "Point Name is: " & PointName
        Debug.Print "Point Coordinates are: " & PointX; ","; PointY; ","; PointZ
                                              Value = swModel.Extension.SelectByID2(PointName, PointType, PointX, PointY, PointZ, True, Mark, Nothing, 0)
                                                      If Value = False Then Debug.Print "Point " & PointName; " Selected"
        Mark = Mark + 1
        Next i
                                              Wend
                                          End Select
                                  Wend
