So I have a bit of an issue with the cut list of a weldment I am trying to display. It is an unusual one because this is the first time I am having an issue like this on a weldment cut list.
I have a mirror of a weldment so I placed the dimensions in so I can re-create the cut list for the mirrored components.
Created the dimensions and then input them the same way I would normally.
Cut list table displayed dimension name instead of dimension values.
Double checked cut list properties and displays numbers correctly.
Double checked the cut list table preview tab, numbers display correctly.
Re-inserted cut list into drawing file.
None of these things changed the display of the cut list.
Attached are some screen grabs of what I am having issues with.
What is the best solution for this issue?
There have been a number of issues with cut lists showing the text string instead of the value, I believe starting with SW2015. I'm not making any promises, but try de-selecting the two options shown below:
