Any idea why this macro would run on 2018, but not on 2016 or 2017?
in 2016 and 2017 I get:
Run-time error '91':
Object variable or With block variable not set.
All it should need is a drawing open with a note on a layer named DEL ME.
' How to delete all notes on a specified layer.
' Preconditions:
' 1. Open ball_valve.slddrw.
' 2. Double-click the note DELETE ME NOTE
' to open the Note PropertyManager page.
' 3. Scroll to the bottom of the PropertyManager page
' to verify that the note DELETE ME NOTE
' is on the DEL ME layer.
' 4. Click a blank area in the drawing sheet to close
' the Note PropertyManager page.
' 5. Run the macro.
' Postconditions: The "DELETE ME NOTE" is deleted. The DO NOT
' DELETE ME NOTE remains intact because it does not reside
' on the DEL ME layer.
' NOTE: Do not save any changes when closing the drawing document.
Option Explicit
' Name of layer from which to delete DELETE ME NOTE note
Const DeleteLayer As String = "DEL ME"
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swView As SldWorks.View
Dim swAnn As SldWorks.Annotation
Dim swSelData As SldWorks.SelectData
Dim NumShts As Long
Dim bRet As Boolean
Dim i As Long
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
Set swDraw = swModel
Set swSelData = swSelMgr.CreateSelectData
NumShts = swDraw.GetSheetCount
For i = 1 To NumShts
swDraw.SheetPrevious
Next i
' Clear the selection set for the sheet
swModel.ClearSelection2 True
Set swView = swDraw.GetFirstView
While Not swView Is Nothing
Set swAnn = swView.GetFirstAnnotation3
While Not swAnn Is Nothing
' If the annotation is a note, then determine
' if the layer is DEL ME
If swNote = swAnn.GetType Then
If DeleteLayer = swAnn.Layer Then
' If the layer is the DEL ME layer
' then select the notes residing
' on that layer
bRet = swAnn.Select3(True, swSelData)
Set swAnn = swAnn.GetNext3
Wend
Set swView = swView.GetNextView
Wend
' Delete the selected notes on the DEL ME layer
bRet = swModelDocExt.DeleteSelection2(swDelete_Absorbed)
swDraw.SheetNext
Next i
replace this line
with
Are you running this macro on computer with more than one SW version installed? Check in task manager how many solidworks processes are started.
