I am using a wire group with 2 wires, the first phase wire and another is neutral/ ground.
I want the wire numbering in such a fashion that the single phase wire must be all odd. And ground wires must be even.
I tried modifying from our end and got a result that all phase wires are in odd and ground wires are in even. But the problem is for the first wire under even is undefined. I used the following formula.
IIF(EVEN(EQUIPOTENTIAL_ORDERNO)==true,EQUIPOTENTIAL_ORDERNO)
IIF(ODD(EQUIPOTENTIAL_ORDERNO)==true,EQUIPOTENTIAL_ORDERNO)
So here I got to know that this "IIF" statement works with a syntax 'IIF(CONDITION, TRUE STATEMENT, FALSE STATEMENT)'
Hence we modified the formulae as IIF(ODD(EQUIPOTENTIAL_ORDERNO)==true,EQUIPOTENTIAL_ORDERNO,EQUIPOTENTIAL_ORDERNO+1) and respectively.
So from this above formula, I was getting the things as per the requirement in the 'TEST' window.
But this result is not replicated on schematics.
My only guess would be that you are putting it in the Wire formula rather than the Equipotential formula
Especially if it is working in the test window.
