Hi, I need help applying a color to a part. I have an assembly which has many of the same part. when I apply a color to one of them it applies to all them. Is there a way to change a color to a single part ?
When you right-click on a Part in the Assembly and then click on the drop-down beside the Appearance icon, if you'll select the top option it will apply the change to only the selected instance, and only in the Assembly. If you select the others you'll be editing the Part file so the change will apply to all instances.
