13 Replies Latest reply on Apr 18, 2018 9:42 AM by Jason Martin
    Create automatic sheet metal flat panel configurations?
    Jason Martin
      I have a sheet metal part but I was wondering if there was something that automatically gives every configuration a Flat_Pattern sub-configuration if it recognizes it as being a sheet metal part.
      It seems that I have placed a part in a drawing and selected the flat panel selection as a view at one time and it populated my whole sheet metal file with sub-configurations. I cannot for the life of me replicate this. I must be missing something that I've done to make this work.
      If there is no solution, is there a Macro that would work for this?
        • Re: Create automatic sheet metal flat panel configurations?
          Jason Martin
          So, I guess I found the macro I need to do this. But, I just need it to loop for each configuration.
          here is the Thread I found it from Re: Creating flat pattern configuration with help of macro
              Jason Martin
              So, here is my attempt to add the loop in. Now this macro works on any part my co worker sends me that is a sheet metal part. But, he gets an error when he runs it on his computer. I cannot understand what the problem is. The error is in the picture below.
              Dim swModel2 As SldWorks.ModelDoc2
              Dim swConfig As SldWorks.Configuration
              Dim swFeature As SldWorks.Feature
              Dim swView As SldWorks.View
              Dim bSheetMetal As Boolean
              Dim iErrors As Long
              Dim sDrawingTemplate As String
              Dim vConfNameArr As Variant
              Dim sConfigName As String
              Dim nStart As Single
              Dim i As Long
              Dim bShowConfig As Boolean
              Dim bRet As Boolean
              Set swApp = _
              Application.SldWorks
              If swApp.GetDocumentCount() = 0 Then Exit Sub
              Set swModel = swApp.ActiveDoc
              If swModel.GetType() = 2 Then Exit Sub
              If swModel.GetType() = 3 Then Exit Sub
              sDrawingTemplate = swApp.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swDefaultTemplateDrawing)
              If sDrawingTemplate = "" Then
                 MsgBox ("Error Retrieving Drawing Template")
                 Exit Sub
              bSheetMetal = False
              Set swFeature = swModel.FirstFeature
              Do While Not swFeature Is Nothing
                 If swFeature.GetTypeName2() = "SheetMetal" Then
                    bSheetMetal = True
                 Set swFeature = swFeature.GetNextFeature
              Loop
              If bSheetMetal = False Then
                 MsgBox ("This Macro Is For Sheet Metal Parts Only")
                 Exit Sub
                  Debug.Print "File = " + swModel.GetPathName
                  vConfNameArr = swModel.GetConfigurationNames
                  For i = 0 To UBound(vConfNameArr)
                      sConfigName = vConfNameArr(i)
                      bShowConfig = swModel.ShowConfiguration2(sConfigName)
              Set swModel2 = swApp.NewDocument(sDrawingTemplate, swDwgPaperSizes_e.swDwgPaperBsize, 0, 0)
              Set swDraw = swModel2
              Set swView = swDraw.CreateFlatPatternViewFromModelView3(swModel.GetPathName, sConfigName, 0, 0, 0, False, False)
              swModel.ForceRebuild3 (False)
              swApp.QuitDoc (swModel2.GetPathName)
              Set swModel = swApp.ActivateDoc3(swModel.GetPathName, False, swRebuildOnActivation_e.swUserDecision, iErrors)
              Next i
              the debugger shows this line being the problem.
              Arthur McRae
              I have been tasked with making a similar macro, I have not started yet.  I am watching this with great interest.  I have multi-body sheet metal parts as well.  I would also like to include a safe out to dxf as part of the macro for our uses.
