2 Replies Latest reply on Apr 10, 2018 12:41 PM by Arthur McRae
    Adding to Save as PDF Macro
    Andrew Boulton
      I currently have a macro setup to save current drawing file as a pdf in a different location (saving as file name). This works great but it saves the ENTIRE drawing file. I'd like to send another copy of only sheets containing "Assembly" to another location in a PDF. I saw a similar example with someone wanting to create a PDF of all sheets not containing "FLAT" and tried manipulating that code but to no avail.
      Can anyone help or point to a similar thread?
        • Re: Adding to Save as PDF Macro
          Deepak Gupta
          Check this macro if codes can help you Save all sheet(s) as PDF except last
            Arthur McRae
            This is our Save As Macro:
            Option Explicit
            Dim swApp           As SldWorks.SldWorks
            Dim swDoc           As SldWorks.ModelDoc2
            Dim swModelDocExt   As SldWorks.ModelDocExtension
            Dim swCustProp      As CustomPropertyManager
            Dim boolstatus      As Boolean
            Dim longstatus      As Long, longwarnings As Long
            Dim Prop_N()        As String
            Dim iReply          As String
            Dim saveDir         As String, FileDir As String, FileName As String, sRev As String, sP_Numb As String, sStatus As String
            Dim FileExt(1 To 2) As String
            Dim FileChk         As Boolean
            Set swDoc = swApp.ActiveDoc
            'check that a File is open
            If swDoc Is Nothing Then
            iReply = "No File open"
            MsgBox iReply
            End
            Set swModelDocExt = swDoc.Extension
            Set swCustProp = swModelDocExt.CustomPropertyManager("")
            Prop_N() = Split("Status, PROJECT NO, Revision, CheckedBy, Description", ", ")
            'iReply = "WARNING! Macro underdevelopment"
            'MsgBox iReply
            'Checks to make sure current file is a drawing
            If swDoc.GetType <> swDocDRAWING Then
            FrmDrwChk.Show
            sRev = 1
            Else
            Dim I As Integer
            Dim val As String, valout As String
            For I = 0 To UBound(Prop_N)
            boolstatus = swCustProp.Get4(Prop_N(I), False, val, valout)
            'Debug.Print "Value:                    " & val
            'Debug.Print "Evaluated value:          " & valout
            'Debug.Print "Up-to-date data:          " & boolstatus
            Select Case I
                    Case 0
                    sStatus = valout
                    Case 1
                    sP_Numb = valout
                    Case 2
                    sRev = valout
                    Case 3
                    If valout <> " " Or valout <> "" Or UCase(valout) <> "XX" Then
                    Debug.Print "Checked by:                " & valout
                    FileChk = True
                    Else
                    FileChk = False
                    Case 4
                    Debug.Print "Description:               " & valout
                    Case Else
                    MsgBox "Unrecognized Property"
            End Select
            Next I
            'set up file extensions
            FileExt(1) = ".PDF"
            FileExt(2) = ".EDRW"
            'Gets current file name and path
            FileName = swDoc.GetPathName
            Debug.Print FileName
            'strips solidworks extension off name and replaces with pdf
            FileDir = Left(FileName, Len(FileName) - 7)
            If InStr(UCase(FileDir), "MODEL") = 0 Then
            saveDir = Left(FileDir, InStrRev(FileDir, "\"))
            Else: saveDir = Left(FileDir, InStr(UCase(FileDir), "MODEL") + 5) & "PUBLISHED\"
            FileName = Right(FileDir, Len(FileDir) - InStrRev(FileDir, "\"))
            'Revison format
            If sRev = CStr("1") Or sRev = "" Then
            sRev = ""
            Else
            sRev = "_R" & sRev
            'Project Number Format
            'sP_Numb = Mid(sP_Numb, 2, 5)
            'If IsNumeric(sP_Numb) = True Then
            'sP_Numb = "P" & sP_Numb
            '    If InStr(FileName, sP_Numb) = 0 Then
            '    FileName = sP_Numb & "_" & FileName
            '    End If
            'Else
            'sP_Numb = ""
            'End If
            'Project Number Format & SERVICE #
            Dim SPN_type As Integer
            If Mid(sP_Numb, 1, 1) = "P" Then
            sP_Numb = Mid(sP_Numb, 1, 6)
            SPN_type = 2
            ElseIf UCase(Mid(sP_Numb, 1, 3)) = "SER" Then
            sP_Numb = Mid(sP_Numb, 1, 8)
            SPN_type = 4
            Else
            SPN_type = 1
                If IsNumeric(Mid(sP_Numb, SPN_type, 5)) = True Then
                Else
            sP_Numb = ""
            'save loop
            For I = 1 To 2
            ' File checked Msg
            If sStatus = "FOR FAB" And FileChk <> True Then
            MsgBox "File not checked."
            boolstatus = FileSave(saveDir, FileName, sRev, FileExt(I))
            If sStatus <> "FOR FAB" Then
            Exit For
            Next I
            Function FileSave(DIR As String, NAME As String, REV As String, EXT As String)
            Dim SaveOption As String
            If EXT = ".EDRW" Then
            SaveOption = swEdrawingSaveAll
            Else
            SaveOption = swSaveAsOptions_Silent
            boolstatus = Application.SldWorks.ActiveDoc.Extension.SaveAs(DIR & NAME & REV & EXT, swSaveAsCurrentVersion, SaveOption, Nothing, longstatus, longwarnings)
            'Debug.Print "Error: " & longstatus & vbNewLine & "Warning: " & longwarnings
            End Function
