Change colour of assembly
Question asked by Andrzej Kurlapski on Apr 9, 2018
Latest reply on Apr 10, 2018 by Andrzej Kurlapski
Hello
I have problem with macro to change part and assembly color. The section for changing color of part is working correct but for assembly it doesn't. When I run the macro in the assembly, the color is changes ,but I can not see it. I must close the assembly and re-open to see the changes. Is it possible to change the color in assembly without re-open document? Below is my code:
Option Explicit
Public Enum swBodyType_e
    swSolidBody = 0
    swSheetBody = 1
    swWireBody = 2
    swMinimumBody = 3
    swGeneralBody = 4
    swEmptyBody = 5
End Enum
Sub ProcessBodyArray(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, vBodyArr As Variant)
    Dim vBody As Variant
    Dim swBody As SldWorks.Body2
    Dim vMatProp(8) As Double
    Dim boolstatus As Boolean
    For Each vBody In vBodyArr
        Set swBody = vBody
        vMatProp(0) = 0
        vMatProp(1) = 1
        vMatProp(2) = 1
        vMatProp(3) = 1
        vMatProp(4) = 1
        vMatProp(5) = 0.5
        vMatProp(6) = 0.4
        vMatProp(7) = 0
        vMatProp(8) = 0
        swBody.MaterialPropertyValues2 = vMatProp
        Set swModel = swApp.ActiveDoc
        boolstatus = swModel.ForceRebuild3(True)
    Next
    Dim swAss As SldWorks.AssemblyDoc
    Dim vBodyArr As Variant
    Dim i  As Long
    Dim bool As Boolean
    Dim name As String
    Dim vMat(8) As Double
    name = swModel.GetPathName
    If Right(name, 6) = "sldprt" Or Right(name, 6) = "SLDPRT" Then
        Set swPart = swModel
        vBodyArr = swPart.GetBodies2(i, False)
        For i = 0 To UBound(vBodyArr)
            If Not IsEmpty(vBodyArr) Then
                ProcessBodyArray swApp, swModel, vBodyArr
        Next i
    Else
        Set swAss = swModel
        vMat(0) = 0
        vMat(1) = 1
        vMat(2) = 1
        vMat(3) = 1
        vMat(4) = 1
        vMat(5) = 0.5
        vMat(6) = 0.4
        vMat(7) = 0
        vMat(8) = 0
        swModel.MaterialPropertyValues = vMat
        bool = swModel.ForceRebuild3(True)
