22 Replies Latest reply on May 15, 2018 4:26 PM by Mário Neto
    Little help with HoleWizard API
    Mário Neto
      Hello!
      I'm trying to write a macro that makes a guiding hole in every end/start point of the bend lines in a sheet metal component. But i'm stuck with this code and can't make it.
      Public Sub main()
          Dim swPartDoc As SldWorks.ModelDoc2
          Dim swFeature As SldWorks.Feature
          Dim swSubFeature As SldWorks.Feature
          Dim vSkSegArr As Variant
          Dim vSkSeg As Variant
          Dim swSkSeg  As SldWorks.SketchSegment
          Dim swSkLine As SldWorks.SketchLine
          Set swPartDoc = swApp.ActiveDoc
          Set swFeature = swPartDoc.FirstFeature
          While Not swFeature Is Nothing
              Select Case swFeature.GetTypeName2
                  Case "FlatPattern"
                      Set swSubFeature = swFeature.GetFirstSubFeature
                      While Not swSubFeature Is Nothing
                          If swSubFeature.Name Like "*Curva-Linhas*" Then
                              Dim swSketch As Sketch
                              Set swSketch = swSubFeature.GetSpecificFeature2
                              vSkSegArr = swSketch.GetSketchSegments
                              For Each vSkSeg In vSkSegArr
                                  Set swSkSeg = vSkSeg
                                  Select Case swSkSeg.GetType
                                      Case swSketchLINE
                                          Set swSkLine = swSkSeg
                                          ProcessSketchLine swApp, swPartDoc, swSketch, swSkLine
                                  End Select
                              Next vSkSeg
                          Set swSubFeature = swSubFeature.GetNextSubFeature
                      Wend
              End Select
              Set swFeature = swFeature.GetNextFeature()
          Wend
      Private Sub ProcessSketchLine(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swSketch As SldWorks.Sketch, swSkLine As SldWorks.SketchLine)
          Dim swStartPt As SldWorks.SketchPoint
          Dim swEndPt As SldWorks.SketchPoint
          Dim swStartModPt As SldWorks.MathPoint
          Dim swEndModPt As SldWorks.MathPoint
          Dim swFeatMgr               As SldWorks.FeatureManager
          Dim swFeat                  As SldWorks.Feature
          Dim swWizHole               As SldWorks.WizardHoleFeatureData2
               Set swFeatMgr = swModel.FeatureManager
          Set swStartPt = swSkLine.GetStartPoint2
          Set swEndPt = swSkLine.GetEndPoint2
      Set swFeat = swFeatMgr.HoleWizard(swWzdHole, _
                          swStandardAnsiMetric, _
                          swStandardAnsiMetricSocketHeadCapScrew, _
                          "M2.0", _
                          swEndCondThroughAll, _
                          2, _
                          2, _
                          swStartPt, _
                          swEndPt, False, False, False, False, False, False, False, False, False, False)
        • Re: Little help with HoleWizard API
          Nilesh Patel
          Hi Mario,
          IFeatureManager::HoleWizard is obsolete now and you should use IFeatureManager::HoleWizard5 method. Have a look at the following example: 2018 SOLIDWORKS API Help - Create Hole Wizard Hole Example (VBA)
          As the API help, you need to select both sketch point before inserting hole wizard.
          Hope this helps.
          Regards,
          Nilesh
            Jacob Corder
            2017 SOLIDWORKS API Help - HoleWizard5 Method (IFeatureManager)
            you cant set swStartPt as an argument to HoleWizard.
            you must preselect those sketch points prior to calling HoleWizard.
            2017 SOLIDWORKS API Help - Insert Hole Wizard Slot and Hole Example (VBA)
                Mário Neto
                Thanks!
                Do i have to select the face also or just the points are enough?
                    Jacob Corder
                    try it and find out.  i am sure selecting the points only works.  because points have a reference to the face they are placed on.
                        Mário Neto
                        Thank you!
                        I'll try it once i have time. Also, i was trying to use this macro http://help.solidworks.com/2016/english/api/sldworksapi/flatten_sheet_metal_part_example_vb.htm?verRedirect=1 to flatten the part, but it doesn't seems to work
                            Nilesh Patel
                            Have a look at the following thread in regards to flatten the part: Bended part flatening script does not work
                                Mário Neto
                                Okay, i managed to flatten the part and select the endpoint, but i can't make the hole, i think i may be doing something wrong...
                                    Nilesh Patel
                                    Hi Mario,
                                    Sorry for the delayed response.
                                    Change SSize = "M2.0" to  SSize = "Ø2.0". If it doesn't work, could you post your macro?
                                    Regards,
                                    Nilesh
                                        Mário Neto
                                        Hello Nilesh, no problem.
                                        I tried that but no sucess, here's the macro:
                                        Public Sub main()
                                            Dim vConfNameArr    As Variant
                                            Dim vSuppStateArr   As Variant
                                            Dim value           As Boolean
                                                    Case "FlatPattern"
                                                        vConfNameArr = swPartDoc.GetConfigurationNames
                                                        vSuppStateArr = swFeature.IsSuppressed2(swThisConfiguration, vConfNameArr)
                                                            Debug.Print "Component Flat Pattern Suppression = " & vSuppStateArr(i)
                                                            If vSuppStateArr(i) = True Then value = swFeature.Select(True)
        value = swPartDoc.EditUnsuppress2
        Debug.Print swSubFeature.Name
        Case swSketchLINE
        End Select
        Next vSkSeg
                                                        Wend
                                                End Select
                                            Wend
                                            Dim swFeatureMgr    As SldWorks.FeatureManager
                                            Dim status          As Boolean
                                                Dim SlotType                    As Long
                                                Dim HoleType                    As Long
                                                Dim StandardIndex               As Long
                                                Dim FastenerTypeIndex           As Long
                                                Dim SSize                       As String
                                                Dim EndType                     As Long
                                                Dim ConvFactorLength            As Double
                                                Dim ConvFactorAngle             As Double
                                                Dim Diameter                    As Double
                                                Dim Depth                       As Double
                                                Dim Length                      As Double
                                                Dim NominalFit                  As Double
                                                Dim ClearanceFit                As Double
                                                Dim PressFit                    As Double
                                                Dim TransitionalFit             As Double
                                                Dim value5                      As Double
                                                Dim value6                      As Double
                                                Dim value7                      As Double
                                                Dim ThreadClass                 As String
                                                Dim value8                      As Double
                                                Dim value9                      As Double
                                                Dim value10                     As Double
                                                Dim value11                     As Double
                                                Dim value12                     As Double
                                                Dim swWizardHoleFeatData        As SldWorks.WizardHoleFeatureData2
                                                Set swFeatureMgr = swModel.FeatureManager
                                                    status = swStartPt.Select(True)
                                                HoleType = swWzdGeneralHoleTypes_e.swWzdHole
                                                StandardIndex = swWzdHoleStandards_e.swStandardAnsiMetric
                                                FastenerTypeIndex = swWzdHoleStandardFastenerTypes_e.swStandardAnsiMetricDowelHole
                                                SSize = "Ø2.0"
                                                EndType = swEndConditions_e.swEndCondThroughAllBoth
                                                Diameter = 2
                                                Depth = 2
                                                Length = -1
                                                'Value1 to Value12 arguments; SOLIDWORKS
                                                'ignores parameters set to -1
                                                NominalFit = 2
                                                ClearanceFit = 2
                                                PressFit = 2
                                                TransitionalFit = 2
                                                value5 = -1
                                                value6 = -1
                                                value7 = -1
                                                value8 = -1
                                                value9 = -1
                                                value10 = -1
                                                value11 = -1
                                                value12 = -1
                                                ThreadClass = ""
                                                Set swFeature = swFeatureMgr.HoleWizard5(HoleType, StandardIndex, FastenerTypeIndex, SSize, EndType, Diameter, Depth, Length, NominalFit, ClearanceFit, PressFit, TransitionalFit, value5, value6, value7, value8, value9, value10, value11, value12, ThreadClass, False, True, True, True, True, False)
                                            Mário Neto
                                            Hi, anything to help here?
                                                Nilesh Patel
                                                Hi Mario,
                                                I finally had a chance to play with your macro. There are few things I would like to highlight:
                                                1. Change the value of 'Diameter' to 0.002 as values in API are in meters. You can either specify 0 or -1 as value for 'Depth' as you have specified the end condition to be through all both.
                                                2. Values of NominalFit, ClearanceFit, PressFit, TransitionalFit actually represent values of Screw Fit, Drill Angle, Near Csink Diameter, Near Csink Angle respectively for regular holes as per API help. Change value of NominalFit to 1 or 2 (depending on the screw fit) and change values of ClearanceFit, PressFit, TransitionalFit to -1.
                                                If you make these changes, it will work well on simple boss extrude feature (even if you select sketch points) but it doesn't work on bend lines. I have tried match transform also but it still doesn't work. When I tried to create the hole using hole wizard manually on bend lines end points, I get the error as per attached image. I guess this is why macro is not working too. Someone else might have better explanation.
                                                The work around is to either create a sketch after you flatten the part and use its sketch points and create hole using hole wizard or simply create cut extrude feature for each bend line end points rather than hole wizard.
                                                Hope this helps.
                                                Regards,
                                                Nilesh
                                                  Nilesh Patel
                                                  Hi Mario,
                                                  I forgot to mention couple of things:
                                                  1. If I select the face (fixed face or the other face) and then run the macro, it creates the holes for bend line end points but it also creates an extra hole for some reason. Also sketch points for hole wizard are not constrained to bend line end points, so if you update the part in future, hole wizard holes won't update properly.
                                                  2. If you create a simple sketch line on the flatten part (even if one of the end point is on the edge)  and then select two end points (instead of selecting bend line end points, you select sketch line end points manually) and run the macro, the macro works fine.
                                                  Another simple work around would be to select the fixed face of the flatten part, create one hole using hole wizard. Then access this hole wizard feature and make the sketch point co-incident with bend line end point. At the same time, you can also create more sketch points (equal to bend line end points) and then make them co-incident. This way, you will only have one hole wizard feature in the feature tree.
                                                  Regards,
                                                  Nilesh
