Off center sheet metal follow bend curve.
Question asked by Nico Van Bever on Apr 4, 2018
Latest reply on Apr 6, 2018 by Andreas Rhomberg
I have a problem creating a bent curve on a sheet metal.
This is the situation, I need to create a curved bend following a circular frame.
The sheet metal rests on the frame (not centered) and follows along for some x cm (here 15) so it can be welded later.
What you see below is just an extrude of a sketch I created by a 'convert entity' of the frame's curve.
But this way (although it looks good) I loose the unfold feature of course, so that's not good...
So what I need is to create a curve on a sheet metal by using the 'sketched bend' feature right?
2 times, to be exact. Once for the angle from the sheet to the frame, and a second on the other side to follow the frame diameter.
Like this:
But how to calculate the initial 1st curve?
How to calculate that curve's exact tangent degree value?
