Hey all,
Since upgrading to to 2017, I noticed my aluminum powdercoat looks flat. I investigated and it appears that plastic, metal, anything with texture now looks flat. Is this a display issue or does it point to something like a missing file (I have had that happen already with the upgrade)?
Hello William,.. not sure what version you upgraded from?... but yes, there was differences with rendered textures from (circ 2012-2014?) what I recall ... mine were mostly light/environment settings but there were some old files which needed to be replaced.
.. was it a saved/past texture file? (change use new files only to test)
.. have you changed your lighting/environment (change/use new files only to test)
.. have you tried increasing the bump mapping or displacement mapping? (old or new)
