Hello, I am having a problem using the trim surfaces command. I am trying to trim the excess material from an extruded shape. I am trying to use the surface of the radius on my surface extrude and plane 1 in my part file to trim the excess material from the boss extrude. I am attaching my part file on here to see if anyone can give suggestion. Much appreciated.
That was the shape i had before i inserted the half circle. I am essentially trying to keep the half circle extrude and remove everything below the half circle up to plane 1
What is the purpose of all of those Workplanes?
Why are you using Surface modeling techniques for this geometry?
Do you have a reference that you are attempting to follow?
I am working on a project where i am reverse engineering a pair of visegrip pliers. I placed the workplanes where they are because that is the location where the handle is going to change its shape and i am working from one end to the other. I am using the surface modeling commands because from my understanding that is the only way i will be able to use the surface trim command.
Ah, I have my students model this design, and we do use surface modeling, but I am having trouble visualizing which part you are attempting to model.
Is this the part you are attempting to model?
Hello Matthew,... as is, you can not trim the solid body with a surface extrude... although you can Cut using a Surface.... but, your surface extrude is open (yes, you checked the cap end)... but the other end is open.. so, you need to close/cap the open end, using a Planar Surface or a Fill Surface.. and can use your existing Sketch35... then, Knit..... so now you can do a Cut using a Surface. (image attached)
Hi Matt,
I'm working on similar but different issue. I think it's a good idea to use solids where you can, when making a complicate part. You can convert your solid to a surface body. By deleting one of the faces of the solid body. From there you can use your surfacing commands to manipulate the surface body.
