3 Replies Latest reply on May 23, 2018 1:42 AM by Chiao Yang Chang
    How to use a scroll bar to control angle in angle mate?
    Chiao Yang Chang
      I want to use scroll bar to control angle between Link1 & Link2.
      But there's an error in .EditMate4 funtion.
      I'm not sure what's wrong with the code.
      Option Explicit
      Const pi = 3.1416159
      Dim swModelDocExt As SldWorks.ModelDocExtension
      Dim swAssembly As SldWorks.AssemblyDoc
      Dim mate As SldWorks.Mate2
      Dim boolstatus As Boolean
      Dim longstatus As Long
      Private Sub hsb_Change()   ' hsb means scroll bar
      Set swModel = swApp.ActiveDoc
      Set swModelDocExt = swModel.Extension
      Set swAssembly = swModel
      ' Mate
      swModel.ClearSelection2 True
      boolstatus = swModelDocExt.SelectByID2("Angle1", "MATE", 0, 0, 0, False, 0, Nothing, 0)
      boolstatus = swModelDocExt.SelectByID2("Front Plane @ Link-1 @ Link_Assemble", "PLANE", 0, 0, 0, False, 1, Nothing, 0)
      boolstatus = swModelDocExt.SelectByID2("Front Plane @ Link-2 @ Link_Assemble", "PLANE", 0, 0, 0, False, 1, Nothing, 0)
      Set mate = swAssembly.EditMate4(swMateType_e.swMateANGLE, swMateAlign_e.swMateAlignALIGNED, False, 0, 0.001, 0.002, 0, 0.001, hsb.Value, 5, 0, False, False, 0, False, longstatus)
      swModel.EditRebuild3
      ' Redraw
      swModel.GraphicsRedraw2
      Private Sub UserForm_Activate()
      hsb.Max = 5
      hsb.Min = 0
      hsb.SmallChange = 1
        • Re: How to use a scroll bar to control angle in angle mate?
          Jacob Corder
          boolstatus = swModelDocExt.SelectByID2("Angle1", "MATE", 0, 0, 0, False, 0, Nothing, 1)
          boolstatus = swModelDocExt.SelectByID2("Front Plane @ Link-1 @ Link_Assemble", "PLANE", 0, 0, 0, False, 1, Nothing, 1)
          boolstatus = swModelDocExt.SelectByID2("Front Plane @ Link-2 @ Link_Assemble", "PLANE", 0, 0, 0, False, 1, Nothing, 1)
          Try this
          select options should be Extensive for multiple selection.  you were clearing the selection per SelectByID2
            Michael Spens
            Hello Chiao,
            I think you'll find better behavior by modifying the angle dimension rather than editing the feature every time.  You might also want to use the Scroll method of the scroll bar.  Move your connections to SOLIDWORKS and the model to the form's Activate method to optimize your processing.  FYI, I changed the scroll bar Max and SmallChange values since my example was in degrees, not radians.  Verify the angle dimension name in your assembly.  Mine was D1@Angle1.
            hsb.Max = 90
            hsb.Min = 0
            hsb.SmallChange = 15
            Private Sub hsb_Scroll()
            Dim myDim As Dimension
            Set myDim = swModel.Parameter("D1@Angle1")
            myDim.SetValue3 hsb.Value, swSetValue_UseCurrentSetting, Nothing
            ' Redraw
