I currently have a three 3D point sketches that represent individual drill locations on a part. I then put these sketches into an assembly with the door (another part, 3D modeled) that they were to be drilled on. I then went to upload the door and points assembly into Solidworks Composer, unfortunately, the door will show up, but not the points. Can anyone give me a suggestion as to how to make those points visible in Composer? Thanks!
Hi Nathan,
Try the following: Import the whole Solidworks Geometry by using the Import Option "Import Points" and "Import curves".
