I have several tables on a drawing and want the edges to be aligned. Is there a way to do this without having to do it just by manually trying to align them. Sometimes I need the top edge aligned and sometimes the left edge.
Edit your sheet format and insert sketch lines where you want your tables to align. You can place them on a Layer that's turned off if you don't want them to show. Exit "Edit sheet format" mode, grab the cross at the upper left corner of the tables to drag them, and when they get close they'll snap to those lines.
