A part started acting strange yesterday. In the part file, it will only show with hidden lines in every display mode. In the assembly, it will show correctly if I select the view through the FM manager tree....unless it's on default display. Then it goes to hidden lines visible when everything else is shaded with lines. I have tried different materials, restarting, restarting again, clearing local cache in PDM.
Quadro P2000 on latest certified driver.
Use the rollback bar to suppress the last feature and I believe you'll see the problem.
