insert circle on mid point of the line
Question asked by Pichaiyan Prabaharan on Mar 28, 2018
Latest reply on Apr 2, 2018 by Pichaiyan Prabaharan
I want to create a sketch over selected surface and offset line from selected edge. And I need to draw a circle in mid point of that line.
I tried below codes,
' select Edge First
' Select Face second
Option Explicit
    Dim swEdge As SldWorks.Edge
    Dim swFace As SldWorks.Face2
    Dim swSelData As SldWorks.SelectData
    Dim swSelData2 As SldWorks.SelectData
    Dim boolstatus As Boolean
    Dim swSketchManager As SldWorks.SketchManager
    Dim status  As Boolean
    Dim swEnt As SldWorks.Entity
    Set swModel = swApp.ActiveDoc
    Set swEdge = swSelMgr.GetSelectedObject6(1, -1)
    Set swSelData = swSelMgr.CreateSelectData
    Set swEnt = swEdge
    swSelData.Mark = 1
    Set swFace = swSelMgr.GetSelectedObject6(2, -1)
    Set swSelData2 = swSelMgr.CreateSelectData
    swSelData2.Mark = 2
    Set swSketchManager = swModel.SketchManager
    swSketchManager.InsertSketch True
    swModel.ClearSelection2 True
    status = swEnt.Select4(True, swSelData)
    'boolstatus = swSketchManager.SketchUseEdge3(False, False)
    boolstatus = swModel.SketchOffsetEntities2(0.001, False, False)
    swModel.Extension.RunCommand swCommands_Edit_Select_All, ""
    swModel.SelectMidpoint
I have 2 problems,
1. offset is not always same side. are we able to fix that?
2. I found a way up to get a mid point, but I don't know how to create circle on that point.
Could any one help with this?
