assign variable to custom property
Question asked by William Miller on Mar 28, 2018
Latest reply on Apr 6, 2018 by William Miller
Hi All,
I am trying to write a macro to automatically take all open drawings and save them as PDF and DXF files. Right now I am currently working on assigning the filename to one of my custom properties but am having issues.  My code is below. For some reason, it says that my property "DrawingNo" is empty. Any ideas what I am doing wrong?
Option Explicit
    Dim swApp               As SldWorks.SldWorks
    Dim swModel             As SldWorks.ModelDoc2
    Dim swModelDocExt       As SldWorks.ModelDocExtension
    Dim swExportData        As SldWorks.ExportPdfData
    Dim filename            As String
    Dim swDraw              As SldWorks.DrawingDoc
    Dim swFeat              As SldWorks.Feature
    Dim swCustProp       As SldWorks.CustomPropertyManager
    Dim swView          As SldWorks.View
    Dim Path As String
    Dim PDFpath As String
    Dim Rev As String
    Set swDraw = swApp.ActiveDoc
    Set swView = swDraw.GetFirstView
    Set swView = swView.GetNextView
    Set swModel = swView.ReferencedDocument
    Set swCustProp = swModel.Extension.CustomPropertyManager(swView.ReferencedConfiguration)
    'Opens folder browser dialogue and prompts user for PDF Folder
    Path = SelectFolder("Select PDF Folder", "C:\Users\USER\Desktop")
    Path = Path + "\"
    'create the PDF directory if it doesn't exist
    PDFpath = Path & "PDF"
    If Dir(PDFpath, vbDirectory) = "" Then MkDir PDFpath
    'Saves as PDF
    Set swDraw = swModel
    filename = swCustProp.Get("DrawingNo")
    Rev = swDraw.CustomInfo("Revision")
    filename = filename & "_REV-" & Rev
    swDraw.SaveAs (PDFpath & filename & ".pdf")
    'Saves as DXF
Function SelectFolder(Optional Title As String, Optional TopFolder _
                         As String) As String
    Dim objShell As New Shell32.Shell
    Dim objFolder As Shell32.Folder
'If you use 16384 instead of 1 on the next line,
'files are also displayed
    Set objFolder = objShell.BrowseForFolder(0, Title, 1, TopFolder)
    If Not objFolder Is Nothing Then
        SelectFolder = objFolder.Items.Item.Path
End Function
