0 Replies Latest reply on Mar 28, 2018 1:39 PM by Dan Pihlaja
    The criteria required in order to use Power Select...
    Dan Pihlaja
      I have been looking into Power Select because I was looking into ways to help this person with this thread: Any way to select bodies with specific material in Multi-Body part?
      2017 SOLIDWORKS Help - Power Select
      I am using SW 2017 SP5.
      When I couldn't access it, I remembered that there were other times that I couldn't access it
      It seems that in order to actually use it, you have to have all the planets aligned.
      Must have "Solidworks Utilities" turned on under Tools--> Add ins
      I did some experimentation and found this criteria.
      # Solid Bodies# Surface BodiesPower Select Available?
      10Yes
      20No
      11Yes
      12Yes
      21Yes
      22No
      02No
      03Yes
      13Yes
      23Yes
      Ok, this must be something screwed up in the programming....maybe?
      Found this:
      Comments?
