PTPeter T.28/03/2018
Hi, When I use the hole wizard to create a countersunk hole it creates it as it should, but when I use the hole wizard again and select a different hole type, the 'Near side countersink' option is always ticked. It is really annoying and sometimes I forget that it has been ticked and add the extra feature, the countersink dimensions are equal to that of the last countersunk hole size I used. So I can end up adding a M3 countersink to a diameter 5.5mm hole or vice versa
