Wend Without While
Question asked by Mário Neto on Mar 27, 2018
Latest reply on Mar 27, 2018 by James Barnes
Hi, i'm getting a "wend without while" in this line of code:
   While Not swFeat Is Nothing
    If Espessura Is Nothing Then
        If swFeat.GetTypeName = "SheetMetal" Then
            Set swsheetmetal = swFeat.GetDefinition
            Thickness = swsheetmetal.Thickness
            conv = 1000
            Thickness = Thickness * conv
                Espessura = Thickness
                    AddCustProp swChildModel
                    AddCorte swChildModel
        Debug.Print " Thickness is :"; Thickness; "milimeters"
            Set swFeat = swFeat.GetNextFeature
    Wend
But it's CLEARYL right there, why is this happening? The full code is:
Public Sub Exporting()
   Dim SwApp                       As SldWorks.SldWorks
   Dim SwModel                     As SldWorks.ModelDoc2
   Dim swAssy                      As SldWorks.AssemblyDoc
   Dim swConf                      As SldWorks.Configuration
   Dim swRootComp                  As SldWorks.Component2
   Dim nStart                      As Single
   Dim bRet                        As Boolean
   Set SwApp = Application.SldWorks
   Set SwModel = SwApp.ActiveDoc
   Set swConf = SwModel.GetActiveConfiguration
   Set swRootComp = swConf.GetRootComponent3(True)
        If SavingPath <= "" Then GoTo Ending Else: GoTo Start:
Start:
   Debug.Print "File = " & SwModel.GetPathName
   TraverseComponent swRootComp, 1
   Debug.Print "Finished!"
Ending:
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp                  As Variant
   Dim swPart                      As SldWorks.PartDoc
   Dim swChildComp                 As SldWorks.Component2
   Dim swConfig                    As SldWorks.Configuration
   Dim swConfMgr                   As SldWorks.ConfigurationManager
   Dim swChildModel                As SldWorks.ModelDoc2
   Dim swChildCustPropMngr         As CustomPropertyManager
   Dim swChildModelDocExt          As ModelDocExtension
   Dim swsheetmetal                As SldWorks.SheetMetalFeatureData
   Dim swFeat                      As SldWorks.Feature
   Dim swBody                      As SldWorks.Body2
   Dim Sheet_metal                 As Boolean
   Dim Boolstatus                  As Boolean
   Dim Thickness                   As Double
   Dim conv                        As Double
   Dim i                           As Long
   Dim loptions                    As Long
   Dim lerrors                     As Long
   Dim sPadStr                     As String
   Dim FilePath                    As String
   Dim FileName                    As String
   Dim swThkDir                    As String
   Dim swMatDir                    As String
   Dim swCurrent                   As String
   Dim RefCfg                      As String
   Dim ChildConfigName             As String
   Dim sMatName                    As String
   Dim sMatDB                      As String
   Dim exFileName                  As String
   Dim Bodies                      As Variant
   Dim Extension                   As Variant
If Not SwModel Is Nothing Then
    If SwModel.GetType = swDocASSEMBLY Then GoTo Assembly Else GoTo Part1
Else: GoTo Fim
Part1:
Set swPart = SwModel
Set swChildModel = SwModel
GoTo Part2:
Assembly:
   vChildComp = swComp.GetChildren
   For i = 0 To UBound(vChildComp)
       Set swChildComp = vChildComp(i)
       'Check to see if current component is suppressed
       If swChildComp.IsSuppressed = False Then GoTo Active Else GoTo Skip
Active:
Set swChildModel = swChildComp.GetModelDoc2
   'Check to see if child component is an Assembly or part
   If (swChildModel.GetType <> swDocPART) Then GoTo Jump 'Skips Subassemby level
Set swPart = swChildModel 'Applies part commands for current component
swCurrent = swChildComp.ReferencedConfiguration 'Get current configuration of component
Part2:
Bodies = swPart.GetBodies2(swBodyType_e.swAllBodies, True)
Set swBody = Bodies(0)
   If swBody.IsSheetMetal = 0 Then 'If Body is not sheet metal
           GoTo Jump
   If swBody.IsSheetMetal = 1 Then 'If body is sheet metal
       Debug.Print "Processing component " & FileName & " as a sheet metal component"
       Debug.Print "Current Config is : "; swCurrent
       GoTo Process
Process:
'Get Part Material
sMatName = swPart.GetMaterialPropertyName2(swCurrent, sMatDB)
If sMatName = "" Then sMatName = "None"
Debug.Print "    Current material is : "; sMatName
'Get File Name
FileName = swChildModel.GetTitle
Debug.Print "File Name is : "; FileName
'Get File Path
sPathName = swPart.GetPathName
Debug.Print "File Path is : "; sPathName
'Get part Thickness
Set swFeat = swChildModel.FirstFeature
            conv = 1000
    Wend
swMatDir = SavingPath & "\" & sMatName
Debug.Print swMatDir
If Dir(swMatDir, vbDirectory) = "" Then MkDir swMatDir
swThkDir = SavingPath & "\" & sMatName & "\" & Thickness & "mm"
Debug.Print swThkDir
If Dir(swThkDir, vbDirectory) = "" Then MkDir swThkDir
exFileName = SavingPath & "\" & sMatName & "\" & Thickness & "\" & FileName
Debug.Print exFileName
Set swOpenModel = SwApp.ActivateDoc3(swChildModel.GetPathName, True, loptions, lerrors)
swChildModel.ExportToDWG2 exFileName & ".DXF", sPathName, swExportToDWG_ExportSheetMetal, True, 0, False, False, options, Null
SwApp.CloseDoc (swChildModel.GetPathName)
GoTo Jump
Skip:
   Debug.Print "Skipped"
Jump:
       TraverseComponent swChildComp, nLevel + 1
          Next i
Fim:
