Hi. I have recently been using SolidWorks composer and I have a problem with the smart arrow feature. When I try to draw one of those I press and hold the alt bottom key and it locks on an axle or something but the problem is that when it crosses through a component, it doesn't hide itself behind that component to show that it's actually in it and you can still see it on top of everything which doesn't illustrate the path perfectly. I saw that the arrow hides automatically in the link below but I don't know how to do it. If anyone knows how to solve this issue, your help will be really appreciated. Thanks https://youtu.be/4Y0SBvd_AKA
Hi Fakhreddin,
this is very easy. To get this behaviour you have to change 1 property of the arrow to off (or Paths or Label or Polyline, ...): "Stay on top" (its the 4. property from top after you select the arrow)
