JBJonathan Barnes23/03/2018
Hi, I'm hoping someone can give me some help.
I'm changing the thickness of a previously created sheet metal part. This in itself is not too much of an issue. However the Thickness equation does not update accordingly. I know this is not a massive issue but maybe a bit of OCD is kicking in.
Should I be amending the equation value? If so , how do I do this?
I have read that you can delete the global variable and then reinstate it with the correct data but I was not able to delete the variable because it was linked.
Any ideas on the subject would be gratefully appreciated.
Jon
