Why does Solidworks show a drill size for a threaded hole call out. This is inappropriate for several reasons.
1. Material hardness or toughness might need a different hole size.
2. The hole size is for a thread cutting tap, what happens if a thread forming tool is wanted, needed or required?
3. The design engineer (me) wants a drawing with a requirement for a threaded hole. I don't want to tell a machinist how to do his job.
4. I really, really don't want a software engineer telling me how to do my job.
There is a file called calloutformat.txt that has two versions that has just the thread specification and hole depth and no drill diameter. The second (apparently default when new software is released) that shows the above call out.
Why?
Dana Patelzick
Solidworks user from 1998.
Edit the calloutformat.txt file to eliminate the tap drill size call out. That is what was done where I work and we have not had any problems in 8 releases (over 18 years).
