Is there a setting in eDrawings to allow sketch lines to show through parts? I'm working with thin circuit boards sandwiched between aluminum plates. I don't use eDrawings very often, but in the past I thought I was able to see the circuit traces (sketch lines) lines through the aluminum plates when I made eDrawings to send to people.
For illustration purposes this example assembly is extra thick. If you rotate it, you can see the lines through the transparent parts but not the aluminum. Anyone know how to fix this? I'm thinking that it might have something to do with the sketch lines being dark gray and not black. They obviously do show through in the Solidworks assembly.
