Re: 3D Sketching with Planes
Swapnil Dhake Mar 21, 2018 8:42 PM (in response to Maha Nadarasa)Just hover over end point of horizontal line once and then you shall get the other line as well.
Maha Nadarasa Mar 21, 2018 8:46 PM (in response to Swapnil Dhake)I tried that as well but it is not coming.
Swapnil Dhake Mar 21, 2018 8:51 PM (in response to Maha Nadarasa)Oh okies, usually it should work. Unfortunately I can't open file to give it a try as SWX says it's in future version. I am using SWX 2017
Maha Nadarasa Mar 21, 2018 9:01 PM (in response to Swapnil Dhake)If you started the sketch from scratch after 2.23 min you will reach the point.
Maha Nadarasa Mar 23, 2018 6:20 AM (in response to Swapnil Dhake)It comes in a 2D mode but not in a 3D mode. I do not know why.
Dennis Bacon Mar 21, 2018 9:30 PM (in response to Maha Nadarasa)That looks like the plane intersection. You can make it any color you want but you have to have "Show intersections checked".. I managed to make the intersection longer by stretching out the planes then autosizing them.
Edit:.. I got around to viewing you video.. Suppose I should have done that earlier.. My bad.
Dave Bear Mar 22, 2018 12:03 AM (in response to Maha Nadarasa)Hi Maha,
If you need a standard 45 degree plane why not just use your top plane as 1st reference and then front plane as 2nd reference and you'll instantly end up with a 45 degree plane. (The new plane can also be flipped and manipulated to suit your needs.)
You just need to pick the 2 correct planes dependant on where you want the 45 degree plane to end up!
Dave.
Maha Nadarasa Mar 22, 2018 1:26 AM (in response to Dave Bear)I have done this by other way but want to know why inference line is not coming.
