Number of refraction in Visualize
Question asked by Ivan Mladenovski on Mar 21, 2018
Latest reply on Mar 22, 2018 by Ivan Mladenovski
Is there a possibility to set up a number of refractions in Visualize (same as in PV), in fast render mode?
On a transparent model after the 4th surface (one after another), I see only black appearance...
- I have 6 transparent surfaces (3 passing bodies, since it calculate the entry side than the exit side it count 6 surfaces), and probably in Fast render there are 4 or 5 refractions by defaults, since I see that black surface only on the last body..
- In accurate mode it's ok.
Can I manually set the number of refractions for Fast render, to have a transparent surfaces without that black at the end (or any other solution to get the result.. )
Thanks in advance.
Regards,
Ivan
