Hi there.
Is it possible to create relations between sketched lines for title block and automatic border lines while editing sheet format?
I'm just working on a drawing template for A1 sized sheet. First I prepared the standard 841 x 594 mm A1 sheet title block with automatic border. (Please see attached "Title_Block_A1" image below). Then when I changed sheet size from 841 mm to 941 mm at sheet properties dialog box, I saw that the title block lines does not follow the automatic border lines moved to right. (Please see "Title_Block_A1_Over_Sized" below). Altough I started the line from the bottom right corner point of automatic border, it does not create a relation between title block line and automatic border line.
Any help would be appreciated. Thanks in advance.
