Make a macro loop throughout parts of an Assembly and its subassemblies
Question asked by Mário Neto on Mar 21, 2018
Latest reply on Mar 22, 2018 by Mário Neto
Hi!
I have a macro that exports a part into a dxf file, but, how can i make it loop through every part in an assembly (Including the ones inside subassemblies)?
Here's the macro:
Option Explicit
Dim sModelName As String
Dim sPathName As String
Dim varAlignment As Variant
Dim dataAlignment(11) As Double
Dim varViews As Variant
Dim dataViews(1) As String
Dim options As Long
Dim FileName As String
Dim FileSaveName As String
Dim swModelExt As ModelDocExtension
Dim swCustProp As CustomPropertyManager
Dim val As String
Dim valout As String
Dim bool As Boolean
    Set swModel = swApp.ActiveDoc
    Set swModelExt = swModel.Extension
    Set swCustProp = swModelExt.CustomPropertyManager("")
    bool = swCustProp.Get4("Espessura", False, val, valout)
    FileName = swModel.GetTitle
    FileSaveName = valout & "mm" & " - " & FileName
    sModelName = swModel.GetPathName
    sPathName = InputBox("Local para Exportação")
    sPathName = sPathName & "\" & FileSaveName & ".dxf"
    Set swPart = swModel
    dataAlignment(0) = 0#
    dataAlignment(1) = 0#
    dataAlignment(2) = 0#
    dataAlignment(3) = 0#
    dataAlignment(4) = 0#
    dataAlignment(5) = 0#
    dataAlignment(6) = 0#
    dataAlignment(7) = 0#
    dataAlignment(8) = 0#
    dataAlignment(9) = 0#
    dataAlignment(10) = 0#
    dataAlignment(11) = 0#
    varAlignment = dataAlignment
   'Export sheet metal to a single drawing file
    options = 1   'include flat-pattern geometry
    swPart.ExportToDWG2 sPathName, sModelName, swExportToDWG_ExportSheetMetal, True, varAlignment, False, False, options, Null
