As stated in the subject, any idea as what is causing this, besides the following SPR which I don't see having actually fixed it (SPR613108)?
Are they older parts? I have had this happen on a file created in the early 2000's even though it was saved in a newer version. My part had a design table and when opened the excel table was running in compatibility mode (file was a .xls). I hit save as in excel, saved it in a modern version (.xlsx), and then relinked the design table to the part and i was then able to use the feature freeze again.
Can you share a part that has exhibited this behavior? Or will it randomly work and not work on the same part?
Are you talking about freeze bar?
