This content has been marked as final.
Show 5 replies
Re: Modify Selection Scope of a Broken-out Section
Deepak Gupta Mar 20, 2018 2:50 PM (in response to Tom Strohscher)-
Tom Strohscher Mar 20, 2018 3:22 PM (in response to Deepak Gupta)-
Deepak Gupta Mar 20, 2018 3:31 PM (in response to Tom Strohscher)The first picture is showing view property and not broken out section view property. And hence you do not see the section scope tab. Check atatched video showing both the methods I've stated above.
Section Scope.wmv 1.1 MB
Tom Strohscher Mar 21, 2018 8:14 AM (in response to Deepak Gupta)Thanks I tried dozens of times and didn't notice the difference.
It think its logical if they put in under edit definition too.
Deepak Gupta Mar 21, 2018 9:05 AM (in response to Tom Strohscher)Tom Strohscher wrote:
Edit definition let you change depth etc., so I think it is correct;y in place. They may add a button on the edit definition property manager but that means another click to open the same window which can be accessed directly via properties.
