I need a base 0 ordinate to start at the outside of an arc. I'm able to apply this ordinate by selecting the Leaders tab and specifying "Min" under the first arc condition, however any dimensions that I then attempt to add to that ordinate are stacked ontop of eachother at the hole/arc centerline. Is there a fix for this or is it just a glitch? I'm using Solidworks 2018.
Maybe I'm not understanding the problem.
I did the above ordinate dimension by holding down the shift key while selecting the end of the part at the "0" dimension.
I then held down the shift key and selected each of the ends of the slots, released the key and selected the c/l of the first slot.
As you can see, each of the ordinate dimensions was placed properly.
I never had to go into the dimension property manager much less the leaders tab.
Hope this helps.
