I'm rying out the new tab ans slot feature and it looks like it will be a big time saver. I use tabs and slots to aid alignment of parts that are plasma cut out of 1/4" sheet sheet. These are welded together not bent. I like to include a .02 clearance to cut edged of the tab help with assembly, but I need it to be only on the 2 cut edges of the tab. The inner face of the tab and the back edge of the slot should be coplanar. The clearance amount seems to apply all (3) edges of the slot. Is there a way to clearance the tab only or specify an edge not to apply clearance to?
Thanks.
Hi
I asked the very same question a few weeks ago. Sadly not, I'm hoping though that the functionality that we require will make its way into a service pack soon.
Steve
