C#, ReferencePattern and check if IsSuppresed?
Question asked by Henrik Landström on Mar 20, 2018
Latest reply on Mar 22, 2018 by Henrik Landström
Hi
I have standAlone code trying to traverse a assembly and find some key values. Sometimes, there might be a folder named "Bracket Support pattern". In that folder, there should be a CircularPattern and what I am trying to do is to get the following:
Angle of the pattern, number of features, and if any of them are suppressed.
     var circulatPattern = (Feature)featuresInFolder[i];
     Console.WriteLine(" Name of feature: " + circulatPattern.Name);
     Console.WriteLine(" Type of feature: " + circulatPattern.GetTypeName2());
     Dimension d3 = circulatPattern.Parameter("D3");
     Console.WriteLine($"Angle of feature: {d3.Value.ToString()}");
     var subf = (Feature)circulatPattern.GetFirstSubFeature();
     while (subf != null) {
     Console.WriteLine($"Current Subfeature: {subf.Name} of type {subf.GetTypeName2()}");
     var maybeSuppressedInConfig = subf.IsSuppressed2((int)swInConfigurationOpts_e.swAllConfiguration, configurationNames);
     for (int j = 0; j < configurationNames.Length; j++) {
          if(maybeSuppressedInConfig[j]) {
               Console.WriteLine($"Suppresed in {configurationNames[j]}");
          } else {
          Console.WriteLine($"Not suppresed in {configurationNames[j]}");
     subf = subf.GetNextFeature();
     if(subf.GetTypeName2() != "ReferencePattern") { break; }
The issue is that I get false as response to all checks of in a feature is suppressed. Maybe I need to traverse from the feature in the pattern, as that feature type is ReferencePattern and find the component /feature that has the actual IsSuppressed-flag. Or should it be done some other way?
