Use the search tool. Under the tools pulldown, Pick the search you want to use. This will open the search tool separately. From here there is a button/icon to export to Excel.
If you just need the list of files, you can use a Windows Explorer trick. Select all the files in the search results, and then Shift-Right Click and select 'Copy as path'. You can then paste it into Excel or wherever.
